steve8411
Oct 03, 2018Apprentice
Firmware 2.2.1.210 released as of 10/3/18
New firmware is available via the GUI ....
Let's hope for success.
Ryan1919
Oct 08, 2018Tutor
Do you have daisy chain disabled or enabled? Mine was doing the same thing and after I enabled daisy chain everything went back to normal. I have daisy chain enabled but my system is star topography. If your running wireless backhual I would try this and see if it works.
Ulairi
Oct 08, 2018Luminary
Daisy Chain was enabled. I've now disabled it (I'm also in star topology so don't need it) and nothing has changed. The icons keep flashing every 5 secs. A wired connection to one of the satellites is the only one that is supposidley not on the router. However, an iPhone right next to the other satellite must be connected to the sat (?) but it's showing connnection to the Router on the other side of the house.
- Ryan1919Oct 08, 2018TutorI did manually update the firmware and factory reset so maybe that had something to do with it. However even now if I disable daisy chain I experience the same symptoms your describing and when I enabled it again all goes back to normal.
