gm2t2
Dec 20, 2017Aspirant
Firmware Problems w/ Satellites
I updated the firmware on my router before I installed my satelite firmware update. It will not upadte the satelite through software or by doing it outside software. When I go to software update I g...
- Dec 21, 2017
That .img file looks correct.
Did you unzip the file that you downloaded or are you trying to load it from within the zipped file?
gm2t2
Dec 21, 2017Aspirant
After going thru the manual install, it tells me the firmware version I am trying to install is incorrect, please load correct file and try again. RBS50-V2.1..img is the file populated in the correct box.
Streak2
Dec 21, 2017Master
- gm2t2Dec 21, 2017Aspirant
I resynced my satelite and when i logged in orbi it let update it automatically. It is working fine now..
Thanks for all the help could not have done it without ya.
