NTCE
Feb 15, 2021Guide
Firmware update V2.6.2.104 - Internet Freeze, No Internet, Buffering, OFFLINE Status on App
I am having issues since the New Router firmware update. Hardware Version RBR20 Firmware Version V2.6.2.104 GUI Language Version V1.0.0.375 Operation Mode ...
sdklmm
Mar 16, 2021Initiate
Had the same issue. Firmware revert fixed it
- vajimMar 16, 2021Master
Thank you and thank you for saving your time. :smileyhappy:
- sdklmmMar 16, 2021InitiateIt took way to much time anyway. Rolling out defective firmware and not even fixing it is not really acceptable to me. Next router won't be netgear...
sdklmm wrote:
It took way to much time anyway. Rolling out defective firmware and not even fixing it is not really acceptable to me. Next router won't be netgear...I agree
lets ask FURRYe38 why netgear keeps rolling defective firmware? What you may hear is that if it works for them then it must mean you must have a faulty system or you're trying to connect it wrong
looking at some of the posts where he and others try to help, you could spend a whole day of trying the many different scenarios. Most of it appears them trying to understand your network and the sheer joy of living on the edge questions
