Deckard22
May 29, 2018Aspirant
Firmware v2.1.4.14?
Hi there...a support person sent me this version of the firmware via chat...any idea what it is/what it does? It looks more recent than the "current" firmware on my router/satellite. Also, any idea h...
May 29, 2018Guru - Experienced User
Nothing was said about it fixing the wireld back haul problem or not. It was initially intended for users with Apple HomeKit issues. Deckard called in and it was given to him however he's seeing a different problem. You can give it a try if you like and see if it helps any. I would factory reset the router and satellite after applying it and set up from scratch. Add 1 satellite via wireless first and let it get a BLUE LED on top. After that, connect the ethernet cable between the router and satellite and see if you get a BLUE LED on top. Give it 5 minutes for this to reconfigure this...
JMU1998 wrote:
Is this the Beta Firmware we have been waiting on with the wired backhaul fix?
