gr8sho
Dec 13, 2019Virtuoso
Firmware v2.5.1
New version available. Based on the description, doesn’t seem worth the disruption. New Version: V2.5.1.8 Release Notes: [Bug Fix] Fixes JP/AU/CA region can't firmware update issue. [Bug Fix] F...
tagteam
Dec 14, 2019Virtuoso
MikeG63 wrote:For me it came up on both the web interface and IOS app. On the web interface I selected ‘check’ for updates and it downloaded and showed it as available. I didn’t have to do anything other than select update all from there.
OK, great! Thank you! This is useful information!!
So, it is not really an auto-update in the sense that you had no control over updating to v2.5.1.8 - it was actually just the download that was automatic and even then only after you manually chose to check for updates. Then, the new version was installed only after you manually selected "Update all".
MikeG63
Dec 14, 2019Apprentice
No, there was no auto update, once the update was downloaded it was ‘manual’ process from there. The good bit was that the device naming issue was fixed - yay 😀
- JetdriveDec 14, 2019Luminary
If you had a choice of whether to install it, it was not an auto update.
- CrimpOnDec 14, 2019Guru - Experienced User
Could it be that this firmware was made available only to customers in the affected countries? JP/AU/CA ?
- MikeG63Dec 14, 2019ApprenticeAstute
- MikeG63Dec 14, 2019ApprenticeI don’t think so - I am UK based. Might be for those who had previously installed v2.5.0.38.
