rp17
Feb 10, 2019Guide
Guest network xbox live
I have an Orbi RBR40 router with 2 satellites. I have a tenant that uses the guest network that has an Xbox. Xbox live will not work property on the guest network saying there is a problem with toredo...
ekhalil
Feb 10, 2019Master
Chuck_M wrote:
The error he referenced was generated from IP6...
I agree that Teredo is an IPv6 protocol and enabling/disabling of iPv6 might have an effect on the behavior.
On the other hand since this works fine in the main wifi network but not on the guest network, one thing to check is the "Allow guests to see each other and access my local network" setting on the Guest Network settings since this is basically the only thing that differenciate the guest network from the main network when it comes to routing.
rp17
Feb 11, 2019Guide
I agree with this but isn’t that basically the point of having the guest account? So they don’t have access to the things on my network?
- ekhalilFeb 11, 2019Master
rp17 wrote:
I agree with this but isn’t that basically the point of having the guest account? So they don’t have access to the things on my network?You are right. We are now just trying to identify the root cause of the issue so that we can then think of the best option to solve it. We need now to know which changes in the settings can have an impact on the behavior you're seeing, and that's why we're suggesting those changes.
