Destructormode
Feb 12, 2019Aspirant
Having large lag spikes on WiFi every 10-15 seconds
Good day forums, I finally made the jump to a mesh network last month with the RBK50, one additional satellite, and one plug in satellite. So far it has been great- I have a large old home with thi...
Feb 16, 2019Guru - Experienced User
What is the size of your home? Sq Ft? 4200
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials. ~15 feet <This a a bit too close. Starting distance is 30 feet.
Destructormode wrote:
Sorry, was out of town for a few days for work. Back now forthe foreseeable future. I was hoping this would have resolved itself, but it is still here. Is it possible my Asus USB-AC68 wifi adapter is just on its way out? Maybed it is not compatible with some new W10 update or something?
What FW is currently loaded? 2.2.1.210
What is the Mfr and model# of the ISP modem the NG router is connected too? Arris Surfboard SB8200
Is the Orbi system operating in Router or AP mode? router mpode
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz. swtiched from auto to manual 2.4ghz 11 and 5ghz 58
Any Wifi Neighbors near by? If so, how many? 4-5 depending on day
What WPA security modes are you using? WEP-PSK
Try enabling Beamforming and MIMO.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Destructormode
Feb 18, 2019Aspirant
^^^ not really an option. The location of the cable entry point to the house is the master bedroom, and the office is one room over. However, my house is 100 years old and constructed very densly with palster and lathe, and the current setup was working for a long time.
