voerman
Mar 18, 2020Aspirant
Help needed with ORBI issue
Router RBR50 with firmware version V2.5.1.8 and behind a modem in bridge modus Satelitte RBS50 with wired backhaul (cat7) and firmware V2.5.1.8 Satelitte RBS50 with wired backhaul (cat7) and firmw...
OrbiPhilip
Mar 18, 2020Luminary
Downgrade. Several people, myself included, have had intermittent connnection issues wuith 2.5.1.8
- voermanMar 18, 2020AspirantDidn’t even know that is possible? How do you manage that?
- voermanMar 18, 2020AspirantTo what version should I downgrade?
- voermanMar 23, 2020Aspirant
I downgraded both satelittes and router to version V2.3.5.30. But still having wifi cut out and the satellites showing up with purple connection (no connection).
Also tried to disable armor but same result.
Any other ideas ? Should I downgrade to another version ? Please help
I consider myself lucky that I am not the guy from Netgear that signed off on a software update that makes wifi unstable just before a period WHERE EVERYBODY IS AT HOME AND NEEDS WIFI!!!!
