Raiden78's avatar
Raiden78
Home network
I have an Orbi RBR40. Intention is to use it as a mesh to improve WiFi access across the house. That works fine. I also discovered the Circle functionality, which I really want to retain.   I attac...
  • plemans's avatar
    Nov 17, 2019
    you're having issues because you've got multiple routers (running in router mode) on your network. you've got a double nat
    https://kb.netgear.com/30186/What-is-Double-NAT
    If you're only using the orbi for wifi coverage, the easiest option is to place it in AP (access point) mode. You lose the ability to run disney circle but the wifi will work fine, the ethernet ports will all work, and you'll still be able to use the fritzbox as you are.
