Reproman
Sep 26, 2022Aspirant
How Do I Login to 2nd Orbi Router From My Computer?
I just upgraded from the RBR50 (Orbi 5) to the RBR750 (Orbi 6) and have both listed in the app to switch back and forth. When I go to orbilogin.net on my computer, I only see the RBR750 router. Is th...
- Sep 26, 2022
Finally got it to work. Forgot the http//. Thanks.
Sep 26, 2022Guru - Experienced User
Have you tried using its ip address? you'll need to be connected to the one that you're wanting to access so be on the same ip subnet
Reproman
Thanks for your quick response. Yes, I tried the IP address for the RBR50 but I get timeout errors. It does work for the IP address of the RBR750, which takes me to the regular login page.
