Droopyougo's avatar
Droopyougo
How to deactivate MAC filtering for Guest network?
Good morning, I have an ORBI sytem deployed at home with a router (SRR60) and two sattelites (SRS60?). I have my home network secured with WKA password and MAC filtering. I wanted to set-up the pr...
  • Droopyougo's avatar
    Droopyougo
    Jul 26, 2019
    Thank you for the comment, but it is not required anymore.
    I received the answer through another channel and what I request is simply not possible with this equipment.
    I consider returning it as it is totally useless to have a system which cannot handle properly a guest network and requires all devices to be white listed.
    Furthermore, I found out that any device connecting to the network, even if it is not authorised, will connect to the main network and get an IP from that network...
    To make a long story short, it is a lie to pretend that this system comes with 3 networks and provide a separate access for "Guests".
    I am very disappointed and will certainly not give it a good publicity/customer review.
