RossBev
Dec 28, 2017Follower
HOW TO DISABLE 5G TEMPORARILY ON ORBI ROUTER
HELLO, I own an Orbi system and recently obtained a Personal Weather station that does direct uploads to various weather sites online. The weather station will only connect to Wi-Fi via a 2.4GHZ sys...
cpasq
Jul 08, 2018Initiate
OK... this thread was very useful and I don't know if I could have succeeded without it... I have finally been able to get my La Crosse weather station connected to my orbi using a macbook. Thanks all!
I did find some minor simplifications to avoid using the numerical IP address of the router... namely, replace the numbers with orbilogin.com. So, here are my notes as gleaned from the thread above and followed in my situation.:
| 1 | Power off the satellites. | |
| 2 | Go to: | http://orbilogin.com/debug.htm |
| 3 | Check "Enable Telnet" | |
| 4 | Open the Terminal application on the MAC | |
| 5 | nc orbilogin.com 23 | |
| 6 | Enter your Orbi router username (admin) and your password at the prompts. (admin/password is the default) | |
| 7 | Paste the following in to disable 5G for a set amount of seconds. This is 300 for now (5 minutes). | |
| seconds=300; x=0; while [ $x -lt $seconds ]; do ip link set down dev $(config get wl5g_NORMAL_AP); x=$(( x + 1 )); echo "down $x"; sleep 1; done | ||
| 8 | Use "Weather Connect" to pair your station. You have 5 minutes if you used the nc (telnet) command above. | |
| 9 | Go to: | http://orbilogin.com/debug.htm |
| 10 | UnCheck "Enable Telnet" | |
| 11 | Power on the satellites. | |
Rhostam
Mar 13, 2019Aspirant
As of 20190313 with Router Firmware Version V2.2.1.210, this "fix" works. Thanks again for summarizing all of the relevant contributions in one spot.
- Ozmeister2019May 20, 2019Tutor
Hi all, thanks for the information shared here. I know this is a few months old but just thought I’d share my findings. I needed to connect my Nest Protect(s) as well as a weather station to my Orbi RBR50 (FW V2.3.1.60), for which for I needed my iPhone to be on the 2.4Ghz Wi-Fi channel.
I found the easiest way to achieve this is to "hide" rather than turn off the 5Ghz channel.(In the absence of anything to easily turn it off)
1)Power off the Satellite.
2)Go into the routers web browser GUI -> Advanced Wireless Settings and then untick Broadcast SSID and WMM for the 5Ghz channel and click Apply.
3)Then go to your iPhone and Wi-Fi settings and click "forget this network", it should then disconnect.(Not sure how to perform "forget this network" on other devices but I assume it's just as easy)
4)Reconnect to your Wi-Fi using the SSID that is now only being broadcast on the 2.4 channel and voila it will have connected to the 2.4Ghz channel.
Afterwards just re tick the options shown in the above screen shot.
Hope someone will find this useful.
- FURRYe38May 20, 2019Guru - Experienced User
Glad the hide the 5Ghz SSID broadcast help you.
Enjoy. :smileywink:
- AguillonJun 24, 2019Aspirant
Gents, I can't thank you enough for the invaluable tips in this thread.
I had just installed a RBK23 at my friend's house but she was getting the dreaded Smart Life app error message "Only 2.4ghz Wi-fi networks are supported" when attempting to set-up her wifi porch lights via the app.
Long story short: got into the Orbi debug page and set up Telnet. Ran IPConfig to find out the router IP address, called it up with PuTTy which I had just installed for that very purpose.
Router responded straight away, asking for username and password.
Copied the Telnet string text and pasted it into PuTTy (little trick here: the Paste command is simply a right click into the PuTTy window).
Presto: a countdown started running and during the 600 seconds I had specified we were able to setup the wifi lights beautifully.
Again, thanks to all of you guys in that thread who have contributed. Absolute life savers the lot of you.
- FURRYe38Jun 24, 2019Guru - Experienced User
Next time, you can easy disable the 5Ghz radio by disabling the 5Ghz SSID broadcast temporarily by taking out the check mark for the 5ghz SSID broadcast Under Advanced Tab/Advanced Settings/Wireless Settings. Once you have the 2.4Ghz devices setup and running, just recheck the enable 5Ghz SSID broadcast.
Enjoy.
Aguillon wrote:Gents, I can't thank you enough for the invaluable tips in this thread.
Yes noted on your solution - I hadn't scrolled to the very last page before I enthusiastically started down the telnet route.
This being said, the geek in me got a massive kick out of going full blown Telnet onto an Orbi. Good fun to get reminded that beneath that polished exterior and web interface, it still talks the same language your 56k modem did 20 years ago...
Maybe however separation of SSIDs isn't officially supported. Disabling of either radio is. The Orbi works as intended. Remember it's the Mfrs of these 2.4Ghz IoT devices and there setup software that is the problem and doesn't allow for setup devices to be on either frequency since both are on the same network techincallly. These Mfrs need to update there setup software so that the setup device can be on either frequency.
