AniDutta
Oct 08, 2016Apprentice
How to force a device to be connected to router and not satellite?
The main Orbi router is in my office and my media room is next to it on the second floor. I have a Chromecast that always connects to the satellite on the first floor. This results in buffering if I c...
peteytesting
Oct 08, 2016Hero
this would suggest the signal from the sat is better than the router and the system is doing the right thing , you cant really tell the client which it should connect to
GaryInEdmond
Dec 06, 2016Guide
The problem with this is, if the satellite signal is only slightly better than the main router, it will connect to the satellite. Unless you are gaming, this is probaly not a big deal. If you are gaming, and your ping doubles because you are connected to the satellite instead of the main router, your gaming performance actually drops. The amplifi HD does this be connecting automatically to the main router unless the signal drops below a certain threshold. It will then connect to the satellite. I hope and pray that netgear adopts a similar approach to their router software.
