JimH4914
Sep 21, 2019Aspirant
How to network with external HD
Returned this as soon as I discovered the USB didn't support HD on my home network. Was I too hasty, is there a workaround?
michaelkenward
Sep 22, 2019Guru - Experienced User
Who knows?
What are you trying to achieve?
If you want to use the Orbi's HD port for local storage, that's a constant complaint. Heaven only knows why Netgear put the USB port there if it does nothing.
JimH4914
Sep 22, 2019Aspirant
My thoughts when I discovered it was useless (to me) when I tried to get my home network back up and running. So sorry it didn't work out as I'd gotten the 53 with 3 units and the coverage in the house was awesome. As good as it was with that, it was useless.
