davidjswift
Nov 19, 2024Follower
Re: How to set up Orbi with optical fiber connection?
I have just had installed gifaclear fibre to the home. They supply a Linksys router how can I replace with the Obi router ?
CrimpOn
Nov 19, 2024Guru - Experienced User
Call their technical support line and ask if their service requires a user login and password.
Typically, the Orbi router would simply replace the Linksys that they supplied.
If there is a monthly charge for the Linksys, it could be returned and taken off the bill.
