webminster
Feb 05, 2018Luminary
How "transparent" is AP switching supposed to be?
Orbi router and satellite pair, running 2.1.2.18. Subject says it all... Noticed on Samsung S5 and my brand new LG V30 running Nougat. Seems like as I wander I get switched between satellite and r...
Jun 08, 2018Guru - Experienced User
What FW version is your Orbi using?
How far are you away from the router or satellite with this device?
Try enableing Beamforming and Fast Roaming and see if anything differs. If your devcies supports MIMO, then you can enabled this as well. You'll have to check with the devices Mfr to see what it supports.
Try using manual channel 1, 6 or 11 on 2.4Ghz and any unused channels on 5Ghz.
SouthernUtahBoy wrote:
I also have an LG V30, and as I roam the house, and even sometimes when I am just sitting on my couch, my V30 will suddenly disconnect, and then reconnect. Highly annoying because sometimes I am casting from my phone to my chromecast connected to my AV receiver, and it interupts the connection. I also don't like it because I don't have an unlimted data plan, and worry about it running my data down faster than it normally would. I don't know what to think, I have not tried contacting Netgear support yet. I think even if I call Netgear, they will point the finger at LG and say it's my phone's fault, and if I call my wireless carrier, or LG, they will point the finger at Netgear and say it's my router. Not sure if it's worth spending hours and hours on the phone trying to diagnose it. Starting to have buyers remorse with this Orbi system because I feel like I shouldn't be having this problem. I also don't have any of those extra options enabled such as beamforming, MIMO, fast switching, because so far from what I have read, everyone says it might make it worse. Just wondering if anyone actually has the fast switching enabled, and if it helped solve any roaming issues? Also, is there a way to FORCE a cell phone to stay connected to the router and not ever transfer to the satellite (which would kinda suck, but would be worth it to solve the problem)? I also heard that some people solved their roaming issues with the ORBI system by connecting to 2.4 GHz only, and not using 5 GHz at all on the device that's having the issue. Not sure how to set that up or try that out either.
webminster
Jun 08, 2018Luminary
When I posted that question way back when, I'd just gotten the V30. Shortly after, I decided as much as I generally liked it, it had some fundamental problems. Took is back and replaced it with an S8. No Samsung fan, but it worked better on wifi (and a other things).
