RudySanchez
May 09, 2019Aspirant
I don't see WIFI router ORBI RBR50
Guys, please I need help. I just received my Orbi Kit RBK53. I succesfully set it up and then I started installing manually the firmware upgrades because the automatic option did not work. When I...
- May 13, 2019
Advanced tab---administration---backup settings--backup
May 13, 2019Guru - Experienced User
Glad you got it updated now. Be sure to backup the routers configuration to file for safe keeping. Please mark your thread as solved so others will know.
Enjoy. :smileywink:
RudySanchez
May 13, 2019Aspirant
Yes I will but one last question. How do I backi it up the routers config files? Where are they?
- plemansMay 13, 2019Guru - Experienced User
