Mikey94025
Sep 25, 2016Hero
Intermittent internet connectivity outage with Orbi?
I just installed my new Orbi router yesterday, replacing a Nighthawk R8500. I believe that overall wireless coverage has improved, though top-end performance is not quite as high (measured via fast....
- Sep 28, 2016
I read in the other "Ring Door Bell" thread that a customer had better results after disabling "Enable Implicit BEAMFORMING". So I tried that just to see what happens. It's probably too early to tell yet, but my 2 Nest cameras have only disconnected once in the past 2 days and I think that's because there was a power outage at my house today (I wasn't home and both cameras went out at the same time, something the intermittent outages haven't done).
Endorphine71
Sep 30, 2016Apprentice
Well... now my Playstation 4 will not connect to the Orbi no matter what I do. I had to do a full reboot on the Router and Satelite before it would connect again.
I also turned off the beamforming option. We will see if this improves the connections issues with the Nest Cams, XBox and PS4. Really starting to think I might need to return this before my time is up it is running so buggy. The admin panel is missing a lot of basic info on connection info.
cggggg
Oct 01, 2016Tutor
Where is the firmware update? Are they even working on a solution? I am about ready to return this to the store.
- JMU1998Jan 19, 2017Luminary
I sure do hope Netgear Engineering is working on new Firmware because many are running out of patience and will start looking at competitors solutions many to choose from now...
I have been able to mitigate this to an extent by rolling back to 1.4.0.16 with a factory reset this same issue started in 1.4.0.18 and persist in 1.4.0.34 Netgear Engineering read these threads and posts so hopefully they are working on next Firmware with a resolution.
