jedfsu
May 17, 2022Tutor
internet disconnecting at least once daily x several months (2??)
We moved to a new home Dec 2021. Using existing Orbi products and switched from Verizon Fios to Xfinity [due to Fios not avail where we are]. I purchase a new Motorola Cable Model MB866 DOCSIS 3.1 M...
May 18, 2022Guru - Experienced User
1. what firmware are you on?
2. when it drops, does anything show in the router logs?
3. have you noticed if the router reboots during this?
jedfsu
May 18, 2022Tutor
Well it seems that my Orbi firmware needs updating so am doing this now! Could this be IT?
I think the Orbi turns purple? Not positive- I need to pay attention next time.
And I’ve not checked router logs - not sure where to find this. I had gotten into the Orbi firmware at one point as my 2.4 network went down & I ended up paying netgear to fix as I did not have time. Some settings were incorrect.
- plemansMay 18, 2022Guru - Experienced User
There was/is a couple of sketchy versions so it might help.
I'd try that first.
If it doesn't help, watch to see if its all devices or just devices connected to a satellite.
You can also try swapping a power supply from one of the satellites to the router and see if its a power supply issue.
- jedfsuMay 18, 2022TutorTy , I don’t think anything is connected to one of the satellites because most everything is in my office that I’m having issues with including my iMac and my VPN phone when it happens. Fingers crossed that firmware update is fixing everything.
Just saying you could swap one of the power supplies from the satellite to the router to see if the routers power supply is going bad.
