jedfsu
May 17, 2022Tutor
internet disconnecting at least once daily x several months (2??)
We moved to a new home Dec 2021. Using existing Orbi products and switched from Verizon Fios to Xfinity [due to Fios not avail where we are]. I purchase a new Motorola Cable Model MB866 DOCSIS 3.1 M...
Jul 03, 2022Guru - Experienced User
Its happening when your devices are directly connected to the router via wire? (not through the satellite)
Does it happen if you're computer is directly wired into the modem?
jedfsu
Jul 03, 2022Tutor
It happens to all devices, some are connected to Orbi base via cable: iMac & Avaya VPN phone, other devices are wireless: iPhones, laptops, Sonos, etc, ooma. everything goes down and then comes back in about 2 min. When occurs, Orbi base station turns purple, modem looks fully functional, all lights are same as when running normally.
has not gone down today so far & I've been working non-stop since 8AM EST [5 hrs 40 min]
difficult for me to plug directly into modem as the problem is so intermittent and others in home need to use internet.
- plemansJul 04, 2022Guru - Experienced User
so you need to start at square 1. (especially if you're unwilling to test just the modem)
shut off all the satellites and just use the modem and the router.
Test that for a period of time and see if it stay stable. If it doesn't then you do need to find a way to test just the modem.
- KevinLiTJul 05, 2022NETGEAR Moderator
Hello jedfsu,
Welcome to the NETGEAR Community!!
I understand that your RBR50 is unstable which causes network outages.
Please ensure that your RBR50 is in AP mode.
To change your RBR50 to AP mode please navigate to the link below:
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
Best,
Kevin
Community Team
- jedfsuJul 05, 2022TutorI did this & now my entire home is down
