DirkO
Mar 02, 2019Apprentice
iOS not showing satellite
Hi,
Hey team Netgear, and team community you all rock !. for years I wanted wire backhaul on the orbi and "whoe Hoe" its working. So big Thanks !!!.
With very low importance I wanted to s...
- Mar 03, 2019
DirkO wrote:
root@RBR50:/# nvram show | grep satellite[1-9]
-satellite1=A0:04:60:17:11:CC 10.0.10.161 RBS50 4PN1685T03620 -100 V2.3.0.32 0 0 0 0 0
So the printouts and logs show that the router sees the satellite but there is no where that confirms that it's wired. Let's try the following change please, try the following telnet commands:
- config set satellite1="A0:04:60:17:11:CC 10.0.10.161 RBS50 4PN1685T03620 -100 V2.3.0.32 1 A0:04:60:17:13:2A wired 1 -100"
- config commit
After this check the attached devices in the web GUI and the Orbi app.
ekhalil
Mar 03, 2019Master
DirkO wrote:
SoapApp. - No such file in the directory.
You will get file if you have the "Save SOAP log between APP and Router" ticked in the debug page as follows:
DirkO wrote:
{2019-03-02 21:11:32}[agent.c:1112] config check start, config is satellite, delimiters is
{2019-03-02 21:11:32}[agent.c:1116] config satellite1 is A0:04:60:17:11:CC 10.0.10.161 RBS50 4PN1685T03620 -100 V2.3.0.32 0 0 0 0 0
Seems that the router is sending the wrong info to the app. In my case I get the following:
{2019-02-28 06:19:51}[agent.c:1116] config satellite1 is 78:C2:94:B5:06:17 192.168.1.2 RBS50 5C81875801359 -97 V2.3.0.32 1 78:C2:94:BA:08:CC wired 1 -97
So it seems that -somehow- the router is not completely recognizing the satellite as wired satellite to the router.
The 5 zeros in your printout should be the status of the satellite's connection to the router as you can see in my printout.
Can you please get the telnet command printouts as well.
DirkO
Mar 03, 2019Apprentice
I updated the previous reply and added the app - Router log.pdf
Euhhh i'm struggling with telnet. (sorry i'm a telnet virgin :)
Qube-MacPro:~ dirko$ telnet 10.0.10.160
-bash: telnet: command not found
Qube-MacPro:~ dirko$ telnet rbr50.qubela.net
