futelihut
Apr 04, 2019Aspirant
IPv6 DHCPv6 Prefix Delegation
Hi
My ISP requires Prefix Delegation for IPv6 support.
Is there a way to configure the RBK50 router to fetch prefix delegation from my ISP?
Or is it not supported?
/Morten
Random12
Apr 05, 2019Apprentice
The prefix delegation bit isn't anything special, I believe you select DHCP as the IPv6 WAN connection type and it should be automatic.
Regards
timch
Apr 05, 2019Luminary
These are my settings but as stated above, I didn’t do anything fancy, it just worked but I know BT uses PD.
