sandman512's avatar
sandman512
Apprentice
Jan 12, 2022
Looking to temporarily disable the the 5GHZ network as to allow my device to connect to the 2.4 GHZ
So, I have an Orbi mesh system , a RBR50 with 3 satellites. I have a device that can only connect to the 2.4 GHZ band. Is there a way to either temp. turn off the 5ghz until the device connects or fo...
  • sandman512's avatar
    sandman512
    Jan 12, 2022
    UPDATE:  So,I turned on location services for the WYZE app and everyting worked.  Thanks!
