Baywatch
Oct 16, 2017Guide
Losing Wireless Connectivity
I have an Amazon Echo Dot. It has worked perfectly here for 6 months on my old wifi system. I upgraded to Orbi AC3000. The Echo Dot connects and works workd fine for a short period of time. Later I t...
Mikey94025
Oct 17, 2017Hero
OK, if the Echo Dot is the only device having issues then just confirming -- Did you go through the wireless setup again after installing your Orbi?
Some customers do not, assuming that the same SSID as their old equipment will work unchanged. Though you mentioned using your Echo Dot at other locations so I assume you have gone through the wireless setup multiple times since installing your Orbi.
Baywatch
Oct 24, 2017Guide
I can't beleive I am only one having this issue ...Echo Dot worked fine before, and still works on my buddies Linksys Velop wifi ... so I am pretty sure this is an Orbi issue !
Hopefully another update will come and it will magically work again.
I'd like to see the option to be able to force an individual device connection to 2.4 or 5 GHz
- coldtechNov 27, 2017Aspirant
I'm having the same issues with my two Echo Dot devices. Before Orbi, they worked perfectly for the whole day without interruption.
And I agree that it would be a very useful feature to force certain devices to certain bands (2G/5G) or even to certain satellites if they are in equal distance between two Orbi devices.
Can somebody give me a clue where to look for this workaround on separating the 2.4 and 5GHz WiFi on the Orbi? I'm willing to give this a shot.
Nevermind, found it: https://community.netgear.com/t5/Orbi/How-to-set-a-separate-SSID-for-the-5-GHz-network-on-your-Orbi/td-p/1396594
And it seems to have helped in my case - I'm maintaining a stable connection of both my Echo Dots for several hours now.
