Baywatch
Oct 16, 2017Guide
Losing Wireless Connectivity
I have an Amazon Echo Dot. It has worked perfectly here for 6 months on my old wifi system. I upgraded to Orbi AC3000. The Echo Dot connects and works workd fine for a short period of time. Later I t...
Gabeloooooo
Oct 25, 2017Guide
I have the exact same issue with Chromecasts / Google Home. They can get into a no net mode and the only fix is to unplug/replug them, then they work for a couple of hours.
My terrible solutions so far are:
- Ethernet adapters for chromecasts
- Use my old router as a wifi AP which I connect the casts/home to. That works 100% but defeats the whole point or Orbi.
Baywatch
Oct 25, 2017Guide
Sorry to hear you are having problems also ... but glad I am not alone.
I have a Google Chromecast Ultra and have not had any issues with Orbi.
But it does sound like we are having a similar problem ... I think this really is an Orbi issue ... some subtle bug that in very specific situations.
- GabelooooooOct 25, 2017Guide
Where are your chromecasts, and where is the echo?
I find the issues happen in the zone between base and satellite. If they are real close to one or the other (never switching), then fewer issues.
- BaywatchOct 25, 2017Guide
Chromecast is near the Router (I am using in AP mode).
I have tried the Echo Dot in many places, even right beside the Router, and still Network is lost in after some time (after a few hours ... not exactly sure as I don't check it repeatedly)
There is a post in this forum where they say how to separate 5G and 2.4G on the Orbi. Although it defeats the purpose of Orbi, have you tried it?
