RedBatman89
Oct 25, 2019Guide
Lots of dos attacks from China?
So I'm getting a bunch of these right now and most of the IP's are from China. What should I do? [DoS Attack: SYN/ACK Scan] from source: 39.107.196.251, port 80, Thursday, October 24, 2019 21:04:...
Oct 25, 2019Guru - Experienced User
YOu might power OFF the ISP modem and RBR, say right before you go to bed, then power ON in the morning and see if the logs are still filling up.
I would contact your ISP and check about changing the WAN IP address to see if this might help some.
RedBatman89 wrote:I mean should I power cycle my modem and prob unit? Or should I call Comcast to change my I'm address?
RedBatman89
Oct 25, 2019Guide
Hi I just wanna say today the logs are much better. The attacks have gone back down to the bare minimum they are at normally. So good thing for that.
- CrimpOnOct 26, 2019Guru - Experienced User
My logs have gone back to normal as well. Was exciting while it lasted.
