agneev
Apr 27, 2020Aspirant
Re: mini UPnPd doesn't update
Continuing the discussion from 1766998.... This issue has still not been fixed with the latest version of Orbi firmware and makes it impossible to track router data usage in apps that support min...
Apr 27, 2020Guru - Experienced User
Have you tried Voxels FW?
- agneevApr 28, 2020Aspirant
FURRYe38 wrote:Have you tried Voxels FW?
I'm not too sure about going that route because a lot of things can go wrong.
Does Voxel have the same UI as NG and is the mobile app compatible?
- FURRYe38Apr 28, 2020Guru - Experienced User
Same UI with minor icon imporvements.
Yes.
I haven't seen things to wrong with Voxels FW while using his FW. Only 1 issue currently is that to reset the system you have to load stock FW back on to the RBR. Voxel is working to correct this item currently.
