agneev
Apr 27, 2020Aspirant
Re: mini UPnPd doesn't update
Continuing the discussion from 1766998.... This issue has still not been fixed with the latest version of Orbi firmware and makes it impossible to track router data usage in apps that support min...
CrimpOn
Apr 27, 2020Guru - Experienced User
agneev wrote:Continuing the discussion from 1766998....
This issue has still not been fixed with the latest version of Orbi firmware and makes it impossible to track router data usage in apps that support miniUPnPd.
Far above my competence level. It is pretty clear that upnpc.c defines the byte counts as "unsigned int" (line 122), which indeed has the maximum value of 4,294,967,295. This is where I flounder: the function call to retrieve the value. Is is wanting an actual binary unsigned int, or is it retrieving a character string and converting it? Back in the days that upnpc was being written, devices that did multi gigabits in one reporting period might have been unusual.
