John_Ba
Apr 22, 2021Luminary
Modem access throuh] router
Its not needed often but in the past I have had to get line stats from my modem. My RBR50 blocks access to my Vigor 130 and when, as just had to do, I need line stats for my ISP I have to get then di...
John_Ba
Apr 23, 2021Luminary
CrimpOn asked about the Orbi address and he was asking about the first 3 parts of the log on address. The Vigor 130 is a modem nothing more so it doesn't need any router fucntions disabl;ing as it doesn't have any.
Ha_Ku_Na
John_Ba wrote:The Vigor 130 is a modem nothing more so it doesn't need any router fucntions disabl;ing as it doesn't have any.
Are you sure ?
https://www.draytek.com/products/vigor130/
When I check the admin GUI simulator:
Then I guess you need to set either:
NAT -> DMZ-Host
or
LAN -> static route
- John_BaApr 23, 2021Luminary
I am unclear as what either are, I have tried adding the modem as a fixed address but it couldn't accept it as its not seeing the modem.
Orbi
- CrimpOnApr 23, 2021Guru - Experienced User
Well, this has been confusing because it appears that the UK deploys DrayTek Vigor 130 set up in bridge mode with all router functions disabled. https://www.draytek.co.uk/support/downloads/vigor-130/send/257-vigor-130/523-vigor130-quickstartguide
So, the question is how to connect to 192.168.2.1 from a computer attached to the Orbi LAN.
The way I understand Orbi operation, is the Orbi WAN port will get a"public" IP address from the ISP.
It will then create an IP subnet on the LAN side, taking 192.168.1.1 for itself and assigning other 192.168.1.x addresses to devices connected to the LAN. As part of the DHCP process, all devices will recognize that any address starting with 192.168.1 is in the local LAN and can be reached by doing an ARP request to learn the MAC address and then sending packets directly to the device. Any other IP address can be reached only by connecting to the gateway IP address (the Orbi), which will then forward packets to the final destination.
192.168.2.1 is not on the local LAN, so the Orbi gateway will attempt to find it. This is where my limited knowledge fails. I do not see how anything can find 192.168.2.1 in this situation. The router should ask the ISP gateway, "where is 192.168.2.1" and the gateway should say, "no idea".
Section 4 of the Quick Start Guide says to set a PC to a static IP address in the 192.168.2.x subnet (mask 255.255.255.0) To me, "this works". PC arps "where is 192.168.2.1" and the Vigor responds "here I am". They talk. (I doubt the PC can access the internet from this static IP.)
I am at a loss to come up with an explanation for how ANY router can reach the modem (Asus included).
Thanks for looking into it. Clearly weather deliberately or not many Asus routers have a way you can access the modem through them. If they intend this I have no idea or what it is that allows it. I either have to make direct connection of change modem, which is why I was asking which modems can be accessed through an Orbi, but if all these are setup differently in different countries may be this is also going to be unknown?
John_Ba wrote:Thanks for looking into it. Clearly wheather deliberately or not many Asus routers have a way you can access the modem through them. If they intend this I have no idea or what it is that allows it. I either have to make direct connection of change modem, which is why I was asking which modems can be accessed through an Orbi, but if all these are setup differently in different countries may be this is also going to be unknown?
I do not know of any "only a modem" that can be access by the customer. (Ignorance, not knowledge).
If the modem was not in 'bridge mode', then the Orbi would be able to connect to it because instead of the Orbi using the public IP address, the Orbi would get a 192.168.2.x IP from the Vigor (and change its own LAN to 10.0.0.x That's clearly not what the ISP intends for customers to do.
Since usage stats are a significant issue for this ISP, maybe a call to their technical support?
- John_BaApr 24, 2021Luminary
Thanks, my ISP didn't supply the 130 I had it befor moving to them. Will just have to link direct ios information is needed again.
