Ghosthunterlife
Jan 03, 2023Aspirant
My RBR20 router giving intermittent internet
I am using a RBR20 Orbi router and it keeps dropping the signal or gives really poor speed. I have 580mps total for my wifi. I have spectrum and the said their modem isn’t the issue. I reboot it and i...
Jan 04, 2023Guru - Experienced User
Please leave feedback to the other question presented as well.
Ghosthunterlife
Jan 04, 2023Aspirant
I have tried everything mentioned in the above windows. Only thing I haven't done is mess with the ip pool numbers because I don't know how or where to find them. . My modem is Spectrum . My orbi isn't blinking Pink when I reset it or anything. I am getting from my Orbi router 580mbps but my 4k max firestick which is 10ft away is only getting 38mbps. Seems very slow. Firmware version is up to date.
- FURRYe38Jan 05, 2023Guru - Experienced User
Be sure to turn OFF the RBS when testing the Firestick.
You can change IP address pool range under Advanced tab/Setup/Lan Setup on the RBRs web page.
Have you set 40Mhz Co-existence as well on the RBR? Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026Is the a model# on the ISP modem somewhere?
- GhosthunterlifeJan 05, 2023AspirantI will try this and see what it does I haven’t configured 40mhz on the web page. Also here is the only model # I could find on the ISP modem EN2251
Ok. I believe that's a Hitron brand mode. Not the greatest.
I'd have the ISP check the signal and everything up to the modem. Might ask the ISP for an upgrade to something different or ask if you can install you own.
