Ghosthunterlife
Jan 03, 2023Aspirant
My RBR20 router giving intermittent internet
I am using a RBR20 Orbi router and it keeps dropping the signal or gives really poor speed. I have 580mps total for my wifi. I have spectrum and the said their modem isn’t the issue. I reboot it and i...
Jan 10, 2023Guru - Experienced User
Is this speed checked with a wired PC connected to the back of the RBR and using Ooklas installable speed test app on the PC?
When you are testing or having things connected, turn OFF the RBS if any are deployed.
How do you have the basic and advanced wireless settings configured?
Do you have Access Controls, Armor, Circle or Traffic meter enabled?
Had a factory reset been performed and setup from scratch after v.24 was loaded?
Ghosthunterlife
Jan 10, 2023Aspirant
Yes that is with a wired. Yes I test my speed with Oaklas on my PC it was 170mbps.
Armor is expired but I never had it when it was first working fine. Traffic meter is off. Factory reset was performed.
- FURRYe38Jan 10, 2023Guru - Experienced User
I try this, find a local store or online store and get you something to try out, something else orbi, non orbi, Nighthawk or non NG. Test this different router out and see if problem resolves or not. Thinking there maybe a problem at the RBR or between the RBR and the modem. Trying a different router should give you direction.
