zhangy
Jul 01, 2018Aspirant
Need able to assign device stay 5ghz
I just purchased the orbi yesterday. Like the idea of merge 2 band into one name. But my lg tv sometime switch to 2.4ghz and makes 4k streamming not working. Some device like google home mini next to ...
mith_it
Jul 02, 2018Luminary
This is purely anecdotal, but I noticed some of my devices occasionally find themselves on a 2.4Ghz network instead of 5Ghz even if I'd have a closer satellite available.
It would be great if there was a way to "incentivize" clients to switch to the best and closest 5Ghz and use 2.4Ghz only when no better option exists.
Personal opinion is that Orbi is better than a regular extender, but isn't a refined system at this point.
loomis1975
Jul 03, 2018Luminary
Right now, I think one of the only things you can do for this situation is adjust the 2.4ghz transmit power level down 1 or 2 steps. It's not a cure all, but it might help. I too wish you could reserve which band to use, just like you can reserve ip address.
- martyfpJul 03, 2018Luminary
loomis1975 wrote:
I too wish you could reserve which band to use, just like you can reserve ip address.I 2nd that request. It would be really beneficial for fixed-location devices that should always be able to connect to the same band.
- Schmak01Jul 04, 2018Apprentice
Just set this up today, on my old router I had separate 2.4 Ghz and 5 Ghz networks, looks like I will have to do that here. I have a MacBook air on 5 G right next to my Surface Book 2 that I am typing this on, inches from each other, and the SB2 defaults to 2.4 which also never goes about 20 Mbps. The 5 Ghz gets up to 80 Mbps, which is just shy of my connection. This is highly annoying.
- loomis1975Jul 04, 2018LuminaryI ran into a similar problem with my work ultrabook Win10 which has an Intel ac 8265 wifi chipset. Since I couldn't fix it on the orbi end, I went into device manager and under advanced tab, changed preferred band to 5.2 ghz from no preference and roaming aggressiveness to medium-high from medium. This seems to be working for me, but would sure be nice to just force it on orbi end.
