Tgterm
Feb 15, 2018Guide
Nest Camera Increased Drops
Not news to anyone here that this happens...but my drop rate has gotten ridiculous! About once per hour, based on the emails I get from the Nest. When I contacted Nest, they informed me that Or...
t_k
Feb 15, 2018Luminary
Tgtermwrote:So...dumb question...is there any way to get the camera to connect to the router if it is nearer to a satellite? I have noticed that sometimes the camera is connected to a satellite (I have 2 sats and one router) that is further away than the one that is closer to it, but I have never seen it connect to the router directly in its current location. Can anything be done to get it to do that?
Thanks!
The question isn't dumb, but the answer is.
The only way to ensure that the router is what your Nest Cameras connect to is to position the router closest to the Nests (and then restart them). Depending on your home layout, that may not be possible.
If more advanced options where available on the Orbi, such as the ability to have SSID's that are only used on a specific AP, then you'd be able to do it. However, the Orbi software development is nowhere near a level where a feature like that would be considered. They can't even get their modest feature set to work with any sort of reliablity.
Tgterm
Feb 15, 2018Guide
That's what I was afraid of...thanks very much for the input! Just restarted my Orbi router to see if that might have any effect, but I am no too optimistic...
