computersteve
Oct 04, 2020Apprentice
Netgear NTP servers down?
Both my RBS50Y and my Orbi Router RBR50 are stating that they cant connect to the Netgear NTP server. I'm in New York on Long Island & this is the Warning: The Orbi Router failed to connect to NTP se...
Mstrbig
Oct 04, 2020Master
computersteve wrote:
I tried. Still reporting the same thing. It’s something with netgear servers. All my other devices using non-Netgear ntp servers are working (Windows, Apple)
I use Netgear's Time servers and have no issues. So it may be that a hub is down in your area preventing you from getting to a series of Domains/IP addresses. This happens sometimes here where they are Hurricanes around.
If it doesn't clear up, change to another server.
computersteve
So, It seems to have gone away. Meaning its working now =) Thanks.
- FURRYe38Oct 04, 2020Guru - Experienced User
Mines still reporting it can't connect. I'll check it this a bit later.
