alfred56
Sep 18, 2018Tutor
Netgear Orbi RBK50 DDNS issue
 Hi Netgear community,
 I have a Netgear Orbi RBK50 Firmware V2.1.4.16 and do not think the DDNS function is updating my host at NO-IP.COM.
 The service is configured with the right hostname...
- Sep 19, 2018This happens sometimes with me. I also have DDNS from No-IP.com. When this happen I just disable DDNS by unticking "Use a Dynamic DNS Service" then Apply the changes and then do the opposite. The DDNS status will show correctly after that --> xxxxxxx updated successfully at 11:01 PM, 09/18/2018
ekhalil
Sep 19, 2018Master
- alfred56Sep 19, 2018Tutor
ekhalil wrote:
This happens sometimes with me. I also have DDNS from No-IP.com. When this happen I just disable DDNS by unticking "Use a Dynamic DNS Service" then Apply the changes and then do the opposite. The DDNS status will show correctly after that --> xxxxxxx updated successfully at 11:01 PM, 09/18/2018Thanks for this tip,, it actually worked!
I got this message this time:
xxxxxxxxxx.ddns.net updated successfully at 08:05 PM, 09/19/2018
Netgear needs to fix up the firmware eventually.
- Christian_RSep 19, 2018NETGEAR Employee Retired
Glad to hear you got it fixed! Thank you for your help on this ekhalil.
Engineers are working to resolve these issues in future firmwares.
~Christian
- ekhalilOct 08, 2018Master
This issue occurs almost always after restart of the router. alfred56, Christian_R
I have to go to the DDNS setting every time the router is restarted and deactivate/activate to get DDNS working again!
 - FURRYe38Sep 19, 2018Guru - Experienced User
Sounds like maybe NG enginneering could make a improvement upon the refresh function of this feature.Glad you figured it out.
