Sep 17, 2020Guru - Experienced User
New - RBR50 / RBS50 Firmware Version 2.5.2.4 Officially Released
Bug Fixes: Fixes the issue where the Nintendo switch failed to connect to the Internet after the Orbi installation due to IP conflicts. Fixes the system stability issues that occurred after the fi...
Ha_Ku_Na
Feb 23, 2021Luminary
vajim wrote:Perhaps...but why post it here? Send it to the brillant firmware developers.
But go ahead and keep updating for its post like these that keep this forum interesting.
I think you have no IT background, because your post(s) are meaningless and do not help to keep this forum interesting ...
Software updates are an important part of the digital landscape.
No software (btw. firmware is software too) is perfect and 100% safe and bug free, therefore it is important to fix vulnerabilities (and this are "the brilliant developers" doing) and update the devices in use.
thisoldhouse
Feb 23, 2021Aspirant
I DO have a background in IT. If you’d bother to read the post the issue was we DID upgrade the firmware per the Netgear advice and it killed our connections. We had to find a way to fix it and tell Netgear how to fix it. Nothing in what I just wrote is acceptable. Netgear needs to be a whole lot better than that when releasing and monitoring firmware updates.
- vajimFeb 23, 2021Master
thisoldhouse wrote:
I DO have a background in IT. If you’d bother to read the post the issue was we DID upgrade the firmware per the Netgear advice and it killed our connections. We had to find a way to fix it and tell Netgear how to fix it. Nothing in what I just wrote is acceptable. Netgear needs to be a whole lot better than that when releasing and monitoring firmware updates.I got all of that. However it was a recommendation to upgrade, meaning it was your choice. I guess that's where your IT background kicks in. Mine failed me.
