Feb 23, 2023Guru - Experienced User
New - RBR50 / RBS50 Firmware Version 2.7.5.4
Bug Fixes: 02/23/2023
This firmware provides the following bug fixes:
Various Armor bug fixes
Various SPC (Smart Parental Control) bug fixes
Security Fixes:
This firmware addresses secu...
- Mar 23, 2023
I recommend a power OFF the the RBR and RBS for 1 minute then back ON with the RBR first then RBS.
Should be fully synced after this.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Jul 24, 2023Guru - Experienced User
I was told a long while back the NG only pushes major FW updated versions and not minor ones. This version is considered a minor update. Along with asking NG to stop auto updating users systems which over the years had a long standing problem when used, and users posted and complained about it many times. NG is giving control back to users in regards to when there systems were updated, means that you as a user control what and when your system needs updating. NG offers the FW when it becomes available and it's up to you users to updated or let the system update, if and when the majors come down the pipe. For minor stuff, it's not that hard to update manually.
Your choice.
Good Luck.
gr8sho
Jul 26, 2023Virtuoso
That’s all fine and understood.
As I said earlier, the issue of whether to update or not gets murky when statements like security fixes are thrown into the fray. I do not care about parental control so anything to update that feature is of no consequence to me personally. Also because I operate my RBR50 as an access point means I’m relying on other hardware for security, and that router gets quarterly updates whether I want them or not.
So yes, in the end I’ll take manual control over forced push any day.
Cheers.
Cheers.
- FURRYe38Jul 26, 2023Guru - Experienced User
