tnadkarni
Jun 17, 2017Star
New beta v1.11.0.8 appears to fix my long time issues
 I've now completed an RMA on both my RBR and RBS with Netgear and sent my old ones back. Running the older beta FW they (the new hardware) was just as bad. But Netgear just sent me a few days ago a n...
ktd
Jun 17, 2017Apprentice
Just installed v1.11.0.8 (10 min ago) and can already see big improvements.
But its to early for me to say that anything really is fixed. But it’s seems to be a good start at least. :)
TomMac
Jun 17, 2017Guru
Yes... been running 1.11.0.2 for a while now ( about 3 weeks) ... all my issues are gone.
No Ipad g2/os 935 not android battery drain issues anymore
The final solution is very near IMO.
- tnadkarniJun 17, 2017Star
Weird .2 was a complete disaster for me but .8 has been great so far.
 - CurlypawsJun 17, 2017Aspirant
Thanks very much TomMac, tnadkarni and ktd - that sounds very promising. How do you get the beta?
- ktdJun 17, 2017Apprentice
Sens DarrenM a PM.
https://community.netgear.com/t5/user/viewprofilepage/user-id/2257
I passed on the positive feedback to Netgear support - I hope the others are doing the same. Hopefully this fixes the issue but even if it doesn't, it appears to be an improvement and should help their engineers know they are on the right track.
I will report back to Netgear but I will wait a few days before doing so. It’s to early to tell if the stability will last.
But it sure looks good. :)
