ekhalil
Jul 11, 2019Master
New Firmware 2.3.5.30
Just updated my Orbi to 2.3.5.30. Seems stable so far. I see few "ads" for the Orbi app and links for app download in the web GUI. Otherwise I could not see much more new things. I'm keeping to loo...
ekhalil
Jul 15, 2019Master
clammerds wrote:ekhalil I've not upgraded mine yet. Can you clarify the reason you had to downgrade in the end? I won't update my firmware if there's a good reason not to.
In 2.3.1.60 there was an issue where the Satellite will get "crazy" and starts affecting the whole system. Symptoms of the issue is that devices will start disconnecting wifi and moving between Satellite and Router every few seconds.
The fix for this issue in 2.3.1.60 was to delete the Satellite from the Router and factory resetting of the Satellite and then syncing the Satellite with the Router (by adding the Satellite as if it was new). That solved the issue in 2.3.1.60 every time this happened. This used to happen every month or more for me.
This exact same issue is also present in 2.3.5.30, BUT the above workaround does not work in 2.3.5.30., which made this software not useable for me. I see waves of wifi disconnects daily and I could not do anything about that. I tried many things but that did not help. Only powering off the Satellite solved the issue.
My analysis of this issue is that it's related to wired devices connected to the Satellite as well as to mesh audio systems. So probably only people with such configuration will see such issues.
timch
Jul 15, 2019Luminary
Just updated my firmware using the web gui. The app wouldn’t do it. All seems to be working fine. I have never needed to do a factory reset so fingers crossed.
- tgltglJul 15, 2019Star
I updated as well (without reconfiguring) and all is working fine with normal speeds. I used the web interface to upgrade.
