Oct 21, 2019Guru - Experienced User
New Firmware v2.5.0.38
All RBK 5 series Orbi's. FW not yet available on the download site for manual installation... Please perform a BACKUP configuration to file. Then update the RBS first then RBR lastly. Factory re...
- Oct 26, 2019
Yes
RJSinMO
Oct 25, 2019Guide
Wow, is there any way to roll this back off??? As stated here, my IPTV is now no longer working reliably. And, all of my named devices are randomly messed up. For example, it says one of my cell phone is on a "wired" connection. My Vonage box (wired) is wireless, etc. This is a really bad release.
RJSinMO
Oct 25, 2019Guide
I just downloaded V2.3.5.30 manually and put my RBR50 and RBS50 both back to that. All my labels are back, and I think IPTV is better. Hopefullyt hey figure it out, I'm not touching V2.3.5.30 again.
- gr8shoOct 26, 2019Virtuoso
tRJSinMO wrote:I just downloaded V2.3.5.30 manually and put my RBR50 and RBS50 both back to that. All my labels are back, and I think IPTV is better. Hopefullyt hey figure it out, I'm not touching V2.3.5.30 again.
Thank you, and well done.
I can do this rollback as well, but I'm worn out and need to take a break from this stuff, and also re-evaluating the situation as trust has been lost.My IPTV had been acting spotty anyway, so unless IGMP is made to work correctly, including through the satellite, I'm just not going to touch it.
- sgraybanOct 26, 2019ApprenticeWhere can you find V2.3.5.30 version ?
How do you rollback on the RBR50 ? I rolled backed on the RBS50 but I see no way to do that with the RBR50. I just see a uplload and upgrade the RBS50.
- FURRYe38Oct 26, 2019Guru - Experienced User
System Uptime 04:18:07:42
On v38. No issues other than the naming of devices.
