Jul 06, 2020Guru - Experienced User
New Orbi 50 series Firmware Version 2.5.1.32 FW Release
RBR50, RBS50, RBK50, and RBK53 New Features and Enhancements: Improves the NTP sync speed and success rate Includes updates to the Terms and Conditions and adds a Privacy Policy link Bug Fix...
Mstrbig
Aug 25, 2020Master
Since there is so much confusion out there, (I know I'm confused), about what firmware is official and what firmware is causing issues, etc., plus the fact that my company installs these systems for customers, I contacted Netgear direct and talked to their support specialist.
According to the Netgear specialist:
"There is no firmware 2.5.1.22, 2.5.1.32 and as well 2.5.2.4 for RBR40, RBR50, even on RBR50v2 -The latest firmware for RBR40, RBR50, RBR50v2 should be "2.5.1.16" - It is Highly suggested that to install firmware for the appropriate model number only which is posted on our Netgear support site. Could you elaborate where you are seeing 2.5.1.22, 2.5.1.32 and 2.5.2.4 for download?"
Many of you are saying that Netgear is pushing these newer firmware to your Orbi systems, but Netgear is saying no. I checked the last 10 installs, and had our customers, check the version number on their Orbi devices. All are on 2.5.1.16 and all systems were new out of the box.
This raises a valid question, as to where these versions are coming from and why some have received them and others not.
So, to take a poll, who received the newer firmware who purchased their product new from an authorized seller, and who received the newer firmware who purchased their product used?
Lyth
Aug 25, 2020Guide
I bought my RBK50 set plus an additional satellite from BestBuy in January of 2018. I was running .32 because I wasn't really having any issue with it and automagically my router and both satellites were updated to 2.5.2.4 without any action on my part.
