SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
Mar 28, 2019Guru - Experienced User
As a last resort, try a factory reset and see what happens. Understand your frustration, shouldn't be like this.
Damit1 wrote:
My RBK50 did this upgrade, auto last night.
Jesus, just like Samsung, untill my Orbi was close to OK, now BOTH Wifi and Wired just ruined.
I really think on selling my kit.
Do not see any happy ending.
Pummelchen
Mar 28, 2019Tutor
Reporting back that speeds are back to normal after some days, get max fiber speed as before (200/100).
Whats broken now is DHCP for IPv6 and IPv4 at least on the notebooks, so I assign them a static address and it works then.
Also link speed seems to fluctuate, my notebook upstaris was steady at 300MBit, now it jumps around 150/180, sometimes lower, sometimes 300. Same with notebook downstairs closer to the router module. Seems signal power was reduced compared to fw 210.
- FURRYe38Mar 28, 2019Guru - Experienced User
Was your system manually or auto updated?
- PummelchenMar 29, 2019Tutor
I updated all manually. The kit arrived with 210 which never showed any updates available.
- FURRYe38Mar 29, 2019Guru - Experienced User
You would have probably needed to upgrade to v212 and v32 first before v44 would have shown in the UI.
