SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
thombe
Apr 04, 2019Apprentice
ok, so problems again after its autoupdated to 44
how can I disable autoupdate so I can stay on .210 for a while please?
mith_it
Apr 04, 2019Luminary
If you manually downgrade to .210 you can then telnet and disable autoupdates. See https://www.reddit.com/r/orbi/comments/8ke43v/how_to_disable_autoupdate/dz6xz9l/
This worked fine for me. As far as I can tell, once you update to .44 if you change those settings it will autoupgrade once (even if you're already on .44) and then not do it again.
CrimpOn FWIW I recently did a factory reset as part of the manual upgrade to .44 and I don't remember seeing a setting to prevent autoupdates.
- Dfran1Apr 04, 2019Apprentice
Thank you mith_it for posting that info ...
i just got got fed up with my video problems due to the WiFi and decided not to reflash .44 and set up from scratch but instead downgrade to 210.
At first when I was on the 44 it seemed to work then days latter problems stared , rebooting helped but a few days latter problems came back.
So today I decided to downgrade to .210 and keep my settings, so no factory reset has been done but I did power cycle both.
I do notice stronger WiFi, great picture streaming , so far , will see over the next week how goes.
Thanks to all!
- FURRYe38Apr 04, 2019Guru - Experienced User
If you have never done a factory reset, then one should be performed. Proven to help solve most issues.
Installed a RBK50 3 days ago with v44. Still running as expected.
Router Firmware Version
V2.3.1.44System Uptime 03:02:13:21
