SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
DougB628
Apr 11, 2019Apprentice
Bullyterrier wrote:
I’ve found you need to do this to ‘clean out’ a satellite config.
Switch satellite off.
Wait until the router gui shows disconnected and then hit remove.
Switch satellite on and immediately factory reset it via the button.
Wait until it finishes booting up
Add new satellite via the gui.
If you just reset the satellite it seems the router just resyncs it complete with any issues.
Thanks for this - I just completed the process, and my secondary satellite now has daisy-chain disabled.
Bullyterrier
Apr 12, 2019Star
If you just reset the satellite it seems the router just resyncs it complete with any issues.Thanks for this - I just completed the process, and my secondary satellite now has daisy-chain disabled.
Thanks for letting me know - that's good confirmation of what I've seen before
