SW_
Apr 18, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.48
Netgear just pushes out another firmware version, 2.3.1.48.
Please share your experience!
LoboTommy
Apr 23, 2019Luminary
Honestly, equipment this expensive should really not have these kind of issues.
It shouldn't matter if I am a plug'n'play user or a computer scientist. It simply should work.
That is what I expect from netgear. Nothing less nothing more. Just the basic. It should work.
All the setups and tweaks and changes and configurations are fine and lovely if I as the user chooses to do so. But, in the bottom of it all, it should just ...work.
How many would buy a car, and accept that you constantly had to tweak the engine, thighten every bolt, position the car south to north, factory reset the car.... just to get it started... and constantly get updates on the cars engine- though you must install it yourself - and 90 days after purchase- the seller is no longer available for support - they only refere you to their other customers....
FuzzyJohn
Apr 23, 2019Tutor
Personally I have not experienced problems with 48, nor with 44 before. I did have problems with 210 and earlier.
That said, I am dumbfounded to see the problems some have with the same hardware and firmware. The only thing that are different are the settings. I cannot fathom that settings would be at the root of this but these forums are proof of it.
The release notes for 48 say "Fixes the GUI display issue when the language is set to Japanese". To take your car analogy the manufacturer issues a recall because the tire pressure label on the door jamb is incorrect. They apply the new, corrected label after with the engine stalls. How can that be.
I said before that it appears the Netgear programmers are incompetent. Netgear should fire the entire team and start over.
- FURRYe38Apr 23, 2019Guru - Experienced User
This is one reason why I recommend that users if they update FW, even manually, factory reset and setup from scratch after new FW versions are applied, IF users are having problems. Some don't have problems, some do. I chose to avoid most of the hassle and bit the bullet and do a reset at each FW update. Setup from scratch then save off a new configuration to file for back up. I haven't seen much issues with this method for FW updates. I do agree that users should not have to resort to this kind of method to keep there systems running. However it is what it is. NG should address what is the root cause of all these issues surrounding each new FW and users seeing problems after updates and results of resets and setup from scratch that seems to fix most of the problems. It's either lingering bad code or bad configurations or mis-configurations that have come incompatible with the new FW thats being applied. Only when a reset and set up from scratch is performed do we see better operation.
I said before that it appears the Netgear programmers are incompetent. Netgear should fire the entire team and start over. - gr8shoApr 23, 2019Virtuoso
And there's probably another category where it may appear there are no problems but in fact there are issues of an intermittent nature like a random buffer that is quickly dismissed and forgotten. The only way to be certain and in a position to trust the network is to start with a clean sheet. ...This doesn't take into account any new bugs that may have been introduced in the new firmware.
Yep. Thats why i start with a clean sheet every time. Elliminate as many problems as possible.
- LoboTommyApr 23, 2019LuminarySo. My router and one satelite is updated. The other two not. Even after countless factory resets, the router do not recognize the satelites, how am I going to set it up from scratch then?
I have forced the same firmware on all four units now, factory reset on all l... guess what orbi GUI (or app) tells me? No satelites found.... - FURRYe38Apr 23, 2019Guru - Experienced User
So if you have all satellites updated and reset. Pressing the sync button on each satellite and the sync button on the router doesn't add the satellites? One at a time?
Checking with the routers web page show connected satellite(s)?
I updated the one satellite I had from v1 FW to v44 and got it connected to the RBR. I just updated it manually yesterday to v48. I did a reset as well, and setup from scratch. The sync does seem to take a while. Pink was on top for a minute or two before the BLUE appeared.
- DorkiOrbiFWApr 23, 2019Apprentice
I have had this happen before, here is the solution that to the issue...
- Login into your Orbi router
- Navigate to the “Advanced” tab
- Go to “Advanced Settings”
- Go to Wireless Settings; under the “Backhaul Topology “ section of those settings, hit the “Generate” button. Sometimes the Orbi satellites will forget the backhaul password if the router (or vice versa) is off for a long period of time.
- Resync Satellites and they should all now appear in the router’s GUI. You’ll then be able to update them as you would.
Hope this resolves the issue, - RCWielewskiApr 23, 2019Aspirant
I already did it and it did not work. Any other suggestions?
So ... I remembered that I can access a windows machine using the terminal server client and I performed what I suggested ... unsuccessfully ... any other suggestions?
- LoboTommyApr 23, 2019LuminaryThat, theorbimechanic, seems to be the closest I have ever seen to a meaningfull solution. I just might have to set up the orbis again and try this.
Let us know how it goes.
The system should come back for you. I would try one satellite at a time, work with one untill it's back online and working. Then turn it off and go to the next one. Do this untill each one is re-sync'd. Once there all done. Then go and place them in there remote locations and turn them on. I would disable Diasy chain first on the RBR, then turn on the satellites.
LoboTommy wrote:
That, theorbimechanic, seems to be the closest I have ever seen to a meaningfull solution. I just might have to set up the orbis again and try this. - LoboTommyApr 23, 2019Luminary
deleted - double message
as i tried to set it up now, I randomly cheked the "Logs".... could this have something to do with my very very unstable network? (I have still only connected the router, so no satelites are set up yet)
Logs:
[DoS Attack: ARP Attack] from source: 192.168.1.2, Tuesday, April 23, 2019 18:12:01
[DHCP IP: 192.168.1.2] to MAC address 70:4d:7b:12:a6:dc, Tuesday, April 23, 2019 18:11:57
[DoS Attack: ARP Attack] from source: 192.168.10.154, Tuesday, April 23, 2019 18:11:00
[DHCP IP: 192.168.1.2] to MAC address 70:4d:7b:12:a6:dc, Tuesday, April 23, 2019 18:10:00
[DoS Attack: ARP Attack] from source: 192.168.10.154, Tuesday, April 23, 2019 18:09:30
[admin login] from source 192.168.1.2, Tuesday, April 23, 2019 18:08:18
[DHCP IP: 192.168.1.2] to MAC address 70:4d:7b:12:a6:dc, Tuesday, April 23, 2019 18:08:05
[DoS Attack: ARP Attack] from source: 192.168.10.154, Tuesday, April 23, 2019 18:08:04
[DoS Attack: ACK Scan] from source: 192.168.10.193, port 8009, Tuesday, April 23, 2019 17:49:21
[DoS Attack: ACK Scan] from source: 192.168.10.193, port 8009, Tuesday, April 23, 2019 17:47:51
[DoS Attack: ACK Scan] from source: 192.168.10.193, port 8009, Tuesday, April 23, 2019 17:47:06
[Time synchronized with NTP server] Tuesday, April 23, 2019 17:46:19
[Initialized, firmware version: V2.3.1.44] Tuesday, April 23, 2019 17:46:06It seems my satelites commits Dos Attacks on the router....
Yes.
What are the devices at the following IPs?
192.168.1.2 and 192.168.10.###?
What is the Mfr and model of the ISP modem again?
The Orbi in Router or AP mode?
Please type in a text diagram of how you have the RBR connected to the ISP modem. Just so we know about this configuration.
Still using v44?
"[Initialized, firmware version: V2.3.1.44] Tuesday, April 23, 2019 17:46:06"
Logs:
My ISP is Altibox fiber network 500/500
My modem is FMG3542 - normally set in bridged mode, so the Orbi are normally set to ... Router mode? (Where do i locate that?)
192.168.1.2 are generally my first satelite. and 192.168.10. are unknown to me.
At the moment 192.168.1.2 are my main computer, as the RBR still won't locate the first RBS - even after following the conigurationsteps recommended
Are you sure the modem is full bridge mode? The RBR should be seeing a public IP address, ##.##.###.### from the modem if fully bridged. Should not be a 192, 10 or maybe a 172 address on the WAN port of the Orbi.
If so, then the RBR should be in Router mode under Advanced Tab/Advanced Settings/Router Mode.
What FW version is on the RBR and the RBS?
When your trying to sync the first RBS, is the distance about 4 feet. It can be this close while trying to add a satellite.
at this moment, I'm not allowed by family to diconnect the running wirless from the FMG, so i just plugged the orbi into one of the ports in the FMG. But nomally when the Orbi runs smoothly, it is solid bridged.
Distance when connectin now is about 30 feet, as the router is on the other side of the living room of to the PC.
When in full bridge mode - what setting of the RBR is correct? Router mode or the other?
I am now manually forcing v44 on the satelites, and keeping that on the router (i dont need japanese)
Ok. so normally when you have Orbi running, you have the modems WIFI disabled when not bridged? This needs to be disabled on the modem if you have the Orbi running.
Yes when modem is fully bridged and wifi disabled, Router mode should be selected on the RBR.
Possible if the satellites were behind on FW then his maybe the reason they were not conneting. RBS have to be updated first before the RBR and be on the same version of FW or RBS can be on a more current version while the RBR can be on a older version of FW. RBS can't be behind in FW versions from the RBR.
text diagram... lets see
see atached file for setup
SO, one satelite is up an running. Shutting it off, and start working on the nest. Taking 20 minute brake now to pick up GF in town
Ok, that gives us conformation of the configuration. Thank you.
So after getting the RBS updated to v44. Factory reset just 1 of them. Turn OFF the others. When you see the top led pulsating WHITE on the RBS, Press the sync button on the RBR then press sync button on the 1 RBS while in the same room as the RBR. Give up to 5 minutes and you should see the top led on the RBS turn BLUE...Lets see if we can get to this point. :smileyfrustrated:
So, when trying to connect the second orbi, it "connected" but in status it said "config sys", ring turns amber, and log says
[DHCP IP: 192.168.1.4] to MAC address 78:d2:94:36:f5:5d, Tuesday, April 23, 2019 19:17:51
[WLAN access rejected: incorrect security] from MAC address 7e:d2:94:36:f5:5f, Tuesday, April 23, 2019 19:16:16
[WLAN access rejected: incorrect security] from MAC address 8a:d2:94:36:f5:5d, Tuesday, April 23, 2019 19:16:05
[WLAN access rejected: incorrect security] from MAC address 7e:d2:94:36:f5:5f, Tuesday, April 23, 2019 19:16:04
[WLAN access rejected: incorrect security] from MAC address 8a:d2:94:36:f5:5d, Tuesday, April 23, 2019 19:16:03
[WLAN access rejected: incorrect security] from MAC address 7e:d2:94:36:f5:5f, Tuesday, April 23, 2019 19:15:56 - FURRYe38Apr 23, 2019Guru - Experienced User
Did you factory reset the RBS then try to re-sync?
yup
