JulesDuf
Sep 05, 2020Aspirant
no connections to satelite
Hi, I bought an Orbi RBR50 and a satelite a bit more than a year ago ; initially everything went fine, but now I just can't connect properly any device to the satelite. Either my devices (phone,...
Mstrbig
Sep 07, 2020Master
Not sure if I asked, if satellites are wireless, is Daisy-Chain Topology checked or unchecked? On depends on how you have your satellites placed. If the furthest satellite relys on the middles satellite, it should be checked.
JulesDuf
Sep 07, 2020Aspirant
I have only one satellite, wireless
- JulesDufSep 09, 2020Aspirant
back to square one, even with the new channel I lose the wifi when I connect to the satellite ; to be more precise if I reboot everything I usually can connect to the satellite and then after 5 min the status of the wifi turns to "connected, no internet". The connection to the main router still works.
Everything was working perfectly for months, I have not changed everything so I really don't know what to do
