poekie68
Jul 15, 2017Initiate
No more wifi schedule in firmware 1.12.0.18
Hi all, Since the firmware update to 1.12.0.18 the possibility to schedule the wifi signal to turn off is not more available. Previously this could be found in Advanced > Advanced Setup > Wirele...
rancho
Oct 30, 2017Initiate
Hi,
this is a very important feature for me too. Could we pls have an update from Netgear/Darren about a possible ETA for the fix ?
Supertramp11
Oct 30, 2017Luminary
Same for me.
If this feature does not make it back in the next FW release, I will have to return my RBK50 with the reason that it does not work as advertised.
Hope this will not be necessary.
- tsaichiNov 14, 2017Initiate
Hi Darren,
Just got mine yesterday updated firmware to V2.0.0.74.
Same problem here no wifi schedule. Can you please inform any progresses on new firmware which could add this feature back?
Thank you,
- Supertramp11Nov 14, 2017Luminary
Through Netgear's german support site I learned that the return of this functionality is not planned by their technical staff.
Unbelievable in times where we like to reduce electrosmog and energy consumption. Users should have the choice to configure this setting as desired. Netgear only leaves us the choice to return the device and look elsewhere. Disappointing, especially in a context where I am quite pleased with this set.
- kemseiDec 10, 2017Aspirant
So that's it? We can just forget about this feature and nobody at Netgear will even consider providing a proper answer?
This is the last time I buy something Netgear, seriously.
