poekie68
Jul 15, 2017Initiate
No more wifi schedule in firmware 1.12.0.18
Hi all, Since the firmware update to 1.12.0.18 the possibility to schedule the wifi signal to turn off is not more available. Previously this could be found in Advanced > Advanced Setup > Wirele...
Aug 10, 2018Guru - Experienced User
You'll need to contact NG support. Theres nothing we can do here in the forums to help you.
Good Luck.
Perts wrote:
Hi Darren
It appears that the Wifi scheduling feature is not a high priority to reintstate and with no clear date as to when this may happen. Considering I purchased the Orbi (in good faith) when this feature was available and advertised as such, I feel that I now have a product that does not do what was promised by Netgear at the time of purchase. With that in mind, can you please provide the information to have this product returned for a full refund so that I can purchase a more suitable product that will serve my purpose.
Regards
Paul
dcreesy
Aug 21, 2018Aspirant
I have now switched to the equivalent TP Link that DOES have a Wi-fi scheduler for the same reasons. I have used Nethear for years but this basic omission is serious enough for me to leave Netgear. All my home security cams are wired but need the router on 24 hours, so a timer on the router is simply not an option.
