nenaang
Feb 29, 2020Aspirant
Old Encryption Error
Hello all, I had a family member connect today and they told me that their ASUS gave them a warning about old encryption. I’ve searched everywhere and do not see this mentioned. Any idea what’s cau...
- Mar 01, 2020
You should be able to update to v2.5.1.8 directly on the RBS first then RBR lastly.
https://www.netgear.com/support/product/RBK50.aspx#download
Download the .zip files for each RBS and RBR. Unpack the .zip file to reveal the .img files. Use IE11, Firefox or Opera web browser on a wire connected PC to send the .img files manually.
Once you get the RBS and RBR updated, factory reset both units and setup from scratch.
nenaang wrote:
Firmware version: v2.3.5.30
Asus T100 (tablet)
WPA2-PSK
CrimpOn
Mar 01, 2020Guru - Experienced User
Unless I am seriously mistaken, the SSL Certificate "issue" remains to this day on the Orbi RBR50 (and I would expect on other models). After the fiasco when the SSL Cert expired, Netgear put a "self-signed" Cert in 2.5.1.8. My Chrome, Edge, Firefox, and Opera browsers ALL complain that the Orbi https web page is "not secure." (4 for 4 = 100%)
My guess is the Asus has a practice of checking that an SSL version of a web site exists and tries to open it instead of the http version.
nenaang
Mar 01, 2020Aspirant
Oh my!!! This is insanity. Thanks for the info.
