nenaang
Feb 29, 2020Aspirant
Old Encryption Error
Hello all, I had a family member connect today and they told me that their ASUS gave them a warning about old encryption. I’ve searched everywhere and do not see this mentioned. Any idea what’s cau...
- Mar 01, 2020
You should be able to update to v2.5.1.8 directly on the RBS first then RBR lastly.
https://www.netgear.com/support/product/RBK50.aspx#download
Download the .zip files for each RBS and RBR. Unpack the .zip file to reveal the .img files. Use IE11, Firefox or Opera web browser on a wire connected PC to send the .img files manually.
Once you get the RBS and RBR updated, factory reset both units and setup from scratch.
nenaang wrote:
Firmware version: v2.3.5.30
Asus T100 (tablet)
WPA2-PSK
Mar 01, 2020Guru - Experienced User
Asus T100 (tablet)
WPA2-PSK
nenaang
Mar 01, 2020Aspirant
ok. thanks. I'll have to find my cables. In the meantime I've switched all devices back to the original router and upgraded that to WPA2 (which it wasn't on...welp!)...
- FURRYe38Mar 01, 2020Guru - Experienced User
:smileywink:
- nenaangMar 06, 2020Aspirant
SUCCESS!!! I didn't even need to use the image files. I clicked into the Orbi on my network (via ethernet) and was able to login and update all 3 through there. After resetting it sill brought up the name of the router so was happy to not have to set that up again. I did make the mistake of trying to add the system as a new setup and it kept trying to connect into a nonexisten wifi network. I finally decided to (after removing and installing the app a couple of times) to just click no to the new setup and was able to go on with my day.
Thanks to you and everyone for their help!
- FURRYe38Mar 06, 2020Guru - Experienced User
Glad you got it working. Be sure to save off a backup configuration to file for safe keeping later on. Saves time if you need to reset later on down the road.
Please mark your thread and solved.
Enjoy. :smileywink:
